| Looking for Deepspar Network add-on http://forum.hddguru.com/viewtopic.php?f=15&t=36112 |
Page 1 of 1 |
| Author: | nicover [ November 24th, 2017, 21:56 ] |
| Post subject: | Looking for Deepspar Network add-on |
Hello, I’m looking for a used Deepspar Network add-on. I’m based in San Francisco,CA Please reply to this message if you have one you’d like to sell. Thanks |
| Author: | data-medics [ November 26th, 2017, 11:14 ] |
| Post subject: | Re: Looking for Deepspar Network add-on |
Umm.....perhaps you don't understand what the network add-on actually is. It's just a feature unlock which allows you to use a standard NIC with the system. You can only buy it direct from DeepSpar since it's just a software unlock. Or you'd have to buy an entire DDI 4 system that's already had that upgraded. There's no hardware included with it. |
| Author: | nicover [ November 27th, 2017, 2:35 ] |
data-medics wrote: Umm.....perhaps you don't understand what the network add-on actually is. It's just a feature unlock which allows you to use a standard NIC with the system. You can only buy it direct from DeepSpar since it's just a software unlock. Or you'd have to buy an entire DDI 4 system that's already had that upgraded. There's no hardware included with it. Oh I thought it was an actual NIC directly connected to DDI4. In this case I will purchase it from Deepspar. Thanks |
| Author: | jermy [ November 27th, 2017, 7:07 ] |
nicover wrote: Oh I thought it was an actual NIC directly connected to DDI4. It is! I.e they send you an Ethernet card but as @data-medics mentioned: 1. you have to unlock it first 2. you can use any NIC card (after unlocking) |
