| USB Add on tool for DDI 4. Whats the going used rate...? http://forum.hddguru.com/viewtopic.php?f=15&t=36664 |
Page 1 of 1 |
| Author: | trumanhw [ April 6th, 2018, 15:21 ] |
| Post subject: | USB Add on tool for DDI 4. Whats the going used rate...? |
Anyone have any suggestions on what a USB addon tool for the DDI4 is worth? Or where I could buy one at an affordable price? I've just bought other equipment so I need to wait a little bit, but I will definitely be getting on. Thanks, Truman |
| Author: | lcoughey [ April 6th, 2018, 15:22 ] |
| Post subject: | Re: USB Add on tool for DDI 4. Whats the going used rate...? |
Assuming that you already have a DDI4, you can only buy the add-on through DeepSpar as it requires both a firmware and hardware upgrade. |
| Author: | Amarbir[CDR-Labs] [ April 8th, 2018, 3:22 ] |
lcoughey wrote: Assuming that you already have a DDI4, you can only buy the add-on through DeepSpar as it requires both a firmware and hardware upgrade. Well, that did not answer his question ,He is asking is it worth it ,I do not have ddi or this hence i am sure you have and can give him a proper response luke |
| Author: | lcoughey [ April 8th, 2018, 5:47 ] |
He didn't ask, "is it worth it?" He asked, "what is it's worth?" |
