| in search of donor for donor drive for a WD15EARS-00MVWB0 http://forum.hddguru.com/viewtopic.php?f=15&t=37365 |
Page 1 of 1 |
| Author: | MrAndersons [ September 10th, 2018, 11:36 ] |
| Post subject: | in search of donor for donor drive for a WD15EARS-00MVWB0 |
Can anyone help me out with a donor drive for a WD15EARS-00MVWB0 with head map 0,1,2,5,6 microjog: 0: C00/3072 1: C4A/3146, 2: C52/3154, 5: C1F/3103, 6: BF9/3065 ? Thanks! Don Anderson Tri-State Data Recovery www.PhiladelphiaDriveRecovery.com |
| Author: | hdd_sand [ September 10th, 2018, 11:59 ] |
| Post subject: | Re: in search of donor for donor drive for a WD15EARS-00MVWB |
MrAndersons wrote: Can anyone help me out with a donor drive for a WD15EARS-00MVWB0 with head map 0,1,2,5,6 microjog: 0: C00/3072 1: C4A/3146, 2: C52/3154, 5: C1F/3103, 6: BF9/3065 ? Thanks! Don Anderson Tri-State Data Recovery http://www.PhiladelphiaDriveRecovery.com They have few you can use... http://www.donordrives.com/catalogsearc ... RS-00MVWB0 |
| Author: | MrAndersons [ September 11th, 2018, 9:49 ] |
I've tried several WCA AZA donors with exact DCM that are within 200 MJ. Last donor I tried the patient killed head 7 which is not a good sign. I have a few more ideas to try... |
| Author: | pclab [ September 11th, 2018, 17:43 ] |
Maybe problem is not in heads, but media damage... |
