| Foxconn 100327114 PCB board http://forum.hddguru.com/viewtopic.php?f=15&t=40012 |
Page 1 of 1 |
| Author: | unknown [ June 10th, 2020, 6:15 ] |
| Post subject: | Re: Foxconn 100327114 PCB board |
wolboy wrote: When plugged into my external reader it switches it off and then when removed that turns on again. You have a TVS problem. search the forum for that issue and this will help you solve your PCB. Good luck |
| Author: | digisupport [ June 10th, 2020, 8:02 ] |
Could be TVS problem, but if data on your drive is important you should stop here and "try" anything. If data is important, you should seek professional help. If the fault is a TVS only, recovery should not be cheap. If data is not important go ahead and fix it yourself. For professional advice or a matching pcb, contact member here "pcimage" http://pcimage.co.uk/ |
| Author: | wolboy [ June 10th, 2020, 8:22 ] |
unknown wrote: wolboy wrote: When plugged into my external reader it switches it off and then when removed that turns on again. You have a TVS problem. search the forum for that issue and this will help you solve your PCB. Good luck Thank you for this I will go and have a look now. |
| Author: | wolboy [ June 10th, 2020, 8:23 ] |
digisupport wrote: Could be TVS problem, but if data on your drive is important you should stop here and "try" anything. If data is important, you should seek professional help. If the fault is a TVS only, recovery should not be cheap. If data is not important go ahead and fix it yourself. For professional advice or a matching pcb, contact member here "pcimage" http://pcimage.co.uk/ I appreciate your advice thank you. |
| Author: | wolboy [ June 10th, 2020, 10:58 ] |
It was in fact the TVS problem I removed the diode and it burst into life so many thanks for all your help. |
| Author: | unknown [ June 10th, 2020, 13:43 ] |
Glad it worked. Don't forget to take a backup ASAP. Good luck |
