| Data recovery from SoC with embedded NOR - start of jurney http://forum.hddguru.com/viewtopic.php?f=15&t=40409 |
Page 1 of 1 |
| Author: | Bolo [ September 18th, 2020, 7:37 ] |
| Post subject: | Data recovery from SoC with embedded NOR - start of jurney |
Hello guys, We want to present new category of adapters we release which allows to read data directly from SoC (CPU) which got internal NOR memory. There are few of such chips from MTK and SPD but on first run goes most popular MTK 6261DA which are installed in many features Nokia phones (as Nokia 106 TA 1114, Nokia 108 RM 944, Nokia 105-2 RM 1133, Nokia 105 TA 1034) and smartwaches. Why you need adapter ? If device is working you don't need it all. It can help you when device are totally demaged (crushed, broken at half). Due to the lack of an SPI or I2C access protocol, the only possibility of accessing the data after a device failure (e.g. breaking the motherboard to prevent access) was to perform a chip SWAP to a functional device. Our adapter revolutionizes data recovery from such cases - just after ChipOFF, place the processor in the adapter and connect the adapter to the USB to enable data reading. ![]() Features: - physical reading of NOR memory directly from ALL processors based on MTK 6261DA (e.g. damaged devices) regardless of the manufacturer - reading deleted Messages, Lists of calls made, Contacts using appropriate investigative software (e.g. Cellebrite UFED, MSAB XRY) - making a full flash copy in order to transfer the content to another device of the same type (duplicate) using e.g. Infinity CM2 or BB5 Best - programming of empty processors directly in the adapter without having to allocate the chip in the decel device NOTE: To perform the reading, appropriate software is required that allows communication with the MTK loader in BROM mode Technical specification: - made from solid monolith block of TecaFORM-H made in Germany and brushed aluminum for durability. - printed circuit made with the highest precision of 4mils and gold plated pads to minimize interference - specially developed PCB tracks routing technology to prevent interference during SoC with PC communication - special high quality pogo contact pins used which are used for specialized laboratory tests Supported device models: - all devices based on the MTK 6261DA processor (regardless of the manufacturer's brand, software versions), i.e. SmartWatch phones and watches - including popular Nokia 106 TA-1114, Nokia 108 RM-944, Nokia 105-2 RM-1133, Nokia phones 105 TA-1034 and others ![]() ![]() Procedure: 1) Make a SoC ChipOff from a damaged motherboard 2) Clean system from tin and flux residues (remove BGA balls) 3) Place the BGA chip in the adapter 4) Run the content reading or programming software (UFD 4PC, MSAB XRY, Infnity CM2, Infinity Best) and select the appropriate service option or reading mode 5) Connect the USB key to the computer How it works - show on UFED 4PC or MSAB XRY YouTube video link - https://youtu.be/cBlvlUPwvTE More informations and orders - https://multi-com.eu/shrt-4XSzaO1Cn Want to be resseler - contact at biuro@multi-com.pl STAY COME FOR MORE SUPRISING PRODUCT SOON......... |
| Author: | sourcerer [ September 18th, 2020, 11:24 ] |
| Post subject: | Re: Data recovery from SoC with embedded NOR - start of jurn |
Very nice! I have been working on the MT6260 research, which is the direct predecessor and very similar, do you support that one as well? Should be easy to enhance I guess. Just wondering, I dont have any active cases with that chip. |
| Author: | Bolo [ September 21st, 2020, 2:28 ] |
It will got diffrent raster and signal output so you cannot use it on same adapter but we can for sure make new one for it |
| Author: | Bolo [ September 23rd, 2020, 15:45 ] |
NEW MOVIES How it works - show on Oxygen Forensic Detective (OFD) YouTube video link - https://www.youtube.com/watch?v=NCZdjmipge4 How it works - show on Infinity Box Dongle/Infinity BB5 Best YouTube video link - https://www.youtube.com/watch?v=ztg42Cc98y8 |
