| DSLOGIC+ for UNI PRO DUAL Plus converter is here !!! http://forum.hddguru.com/viewtopic.php?f=15&t=41147 |
Page 1 of 1 |
| Author: | Bolo [ April 1st, 2021, 2:34 ] |
| Post subject: | DSLOGIC+ for UNI PRO DUAL Plus converter is here !!! |
Next product ready.... this time adapter for conneciton UNI PRO DUAL Plus to DSLogic+ logic analyzers. What it can be.... baisacally it will speed up your owrk while research process similar to ZeroPlus presented here - https://forum.hddguru.com/viewtopic.php?f=15&t=41039 Details as belows.... DSLogic+ for UNI Pro Dua Converter allows the direct connection of the UNI PRO Dual Plus and UNI PRO Dual Plus adapters to the DSLogic Plus (16 channel) logic analyzer. The adapter is irreplaceable during the search and verification of NAND protocol signals, it facilitates and speeds up the work by replacing the standard F-F cables. ![]() ![]() ![]() Movie from connection process - https://youtu.be/hCU_os5QO0g Want to buy it ?? - check at https://multi-com.eu/shrt-FYWz7X3hi More adapters available at https://multi-recovery.com/ |
| Author: | luojifenxiyi [ February 14th, 2022, 14:19 ] |
| Post subject: | Re: DSLOGIC+ for UNI PRO DUAL Plus converter is here !!! |
I would like to ask, how to use a logic analyzer to determine the 8bit flash pin definition. D0, D1, D2, D3, D4, D5, D6, D7 RE, R/B, CE, WE, ALE, CLE. Is there any technical information, or video instructions, thank you all. |
| Author: | Tomset [ February 15th, 2022, 1:38 ] |
Calculation of monolith pinout in 10-15 minutes: http://forum.acelab.ru/viewtopic.php?t=16594 Is there an English version, I don't know. |
| Author: | luojifenxiyi [ February 15th, 2022, 3:57 ] |
Tomset wrote: Calculation of monolith pinout in 10-15 minutes: http://forum.acelab.ru/viewtopic.php?t=16594 Is there an English version, I don't know. Browsing this website requires a password, I can't browse without a password. |
| Author: | Tomset [ February 15th, 2022, 5:26 ] |
luojifenxiyi, If you have AŃelab equipment, request access from support. |
| Author: | Tomset [ February 15th, 2022, 5:49 ] |
https://blog.acelaboratory.com/pc-3000- ... -line.html |
