 Post subject: Use FE adapters with PC3000 Flash ? Why not....
PostPosted: April 13th, 2021, 7:36
We are trying always to make your work easier and faster..... there are some situations that you got BGA316, BGA272 chips where no original adapters are available but you got existing adapters for FE. Now we have solution for you - you can now use them without any problems instead of soldering. We have redesigned it fully to support 8 and 16bit data buses chips.
ACEM-FE 8-16bit converter for PC3000 Flash Multiboard to connect FE adapters is an additional adapter that allows you to connect of Flash-extractor adapters to PC3000 Flash v3/4 (Ace Laboratory) for reading through NAND.
How it's looks connected ?
You can find more info and purchase it here - https://multi-com.eu/,details,id_pr,22642,key,acem-fe-converter-for-pc3000-flash-multiboard-to-connect-fe-adapters,smenu,forensic_tools.html
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
