Buy/sell hard drives, parts, tools
September 5th, 2021, 15:50
I made 7 kinds of boards for WD USB hard disk, I started this board in China in July this year,Now belongs to JUN DA CHENG 。
PC-3000 for WD USB 800067
PC-3000 for WD USB 800069
PC-3000 for WD USB 810003
- 810003.png (71.63 KiB) Viewed 22628 times
PC-3000 for WD USB 810012
PC-3000 for WD USB 810033
PC-3000 for WD USB 810035
PC-3000 for WD USB 800041
I've done several before.
- 2.png (269.29 KiB) Viewed 22628 times
Maybe you've seen similar products. Interested friends can see the launch date,Friends in need can contact me。 XG and 鑫广科技 It's my logo
My QQ:2169571
2169571@qq.com
- Attachments
September 5th, 2021, 22:56
I may have made an editorial error when posting,The probe board itself is not a decryption board. With it, there is no need to weld the USB board into SATA. Simple installation can convert the USB board into SATA interface, and the SED data output of the original board is normal
September 6th, 2021, 17:47
Your website is not working...
Can you post more details, like the prices?
September 6th, 2021, 20:33
pclab wrote:Your website is not working...
Here's what I get when I go to
https://www.jundacheng.com/...
September 7th, 2021, 1:07
Website problems are being repaired
The ownership of UTS probe board belongs to 军成成。 I will no longer participate in the sales work.
I just saw someone plagiarize, So explain the time of my release.
September 7th, 2021, 11:24
I get the same type of message.
September 7th, 2021, 15:57
Went head despite the warning... The website does not seem to be in existence. Maybe is no longer hosted or something.
September 7th, 2021, 16:34
Works for me. Use "http" instead of "https".
http://www.jundacheng.com/bbs/forum.php
September 7th, 2021, 16:47
Their PCBs are very similar to these. Not to say that they are practically the same.
https://www.hddheadtools.com/product-ca ... onnectors/
September 7th, 2021, 23:17
You are not in China and may not know the details. Some of them have received my board. Is to create at the same time, so why are the methods of protecting the probe, including the selection of
黄框内可以生产探针的胶座,箭头指向孔是为了生产胶座固定的孔
The rubber base of the probe can be produced in the Yellow frame. The arrow points to the hole to produce the fixed hole of the rubber base
There are at least three kinds of things. Is there such a coincidence? Can you call it similar?
- Attachments
September 8th, 2021, 8:23
In China, green substrates are for proofing and testing, and later production generally sinks gold. The product has only been uploaded in the past two days and is being updated. Obviously, it is making finished products and then sending drawings. Many people understand this.
Product similarity is OK. However, the protection method of the probe, the method of raising the probe, including the selection of screws, are surprisingly similar. Can't it explain plagiarism?
I am not a professional PCB designer, so there are many mistakes in doing so. I sent several people to help me test, which is also the reason why I was copied. For example, GND should be set at the board fixing column, but it was not set at that time. I have corrected it later, which can be found by comparison.
Introduction and information of UTS board:http://www.jundacheng.com/bbs/forum.php?mod=viewthread&tid=6047
September 8th, 2021, 15:47
So you are the creator of those PCBs and did they copy you?
What is the cost of your PCBs?
