 Post subject: Adapter NAND MR21 v2 - support all 3x7 verions
PostPosted: September 28th, 2021, 9:32
Hello guys,
As always we are working hard every day to make your DR work faster and easier. Today we are back with updated product ;)
In late 2017 we first release MR21 adapter with support 3x7 raster. Across over 4 years we found other cards with diffrent NAND pinout location available which require from us project from scratch new adapter. Today we are ready to show new, updated v2 edition. What changes ??
- prepared to work on the standard and modified 7x3 raster (modified raster got 3x7 on center of card instead 3x7 on bottom as usuall SanDisk) - check photos below
- full support (build in) for SanDisk 200Gb/400 Gb cards two independent NAND chips (in 200 Gb you will found 1ID for 128Gb, second diffrent ID for 64Gb and in 400 Gb cards you will find one crystal for 200 Gb and second for 128Gb)
- support alternative pinout for SanDisk clones
Ofcourse all previous advantages like work with 3 diffrent devices (Pc3K Flash circuit board/Multiboard, FE, VNR or other readers), power mode enable, VCC/GND cutout it's also available here ! Ofcourse all our adapters are developed/produced/assembled in EU !!
Photos:
Supported (normal 3x7)
Support for moved raster (new 3x7)
More here - [url]https://multi-com.eu/,details,id_pr,22720,key,microsd-nand-monolithic-mr21-v2-adapter-diagram-7x3.html
[/url]
All models of adapters available at https://multi-recovery.com/models.php
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
 Post subject: Re: Adapter NAND MR21 v2 - support all 3x7 verions
PostPosted: October 3rd, 2021, 7:23
Is there manual to how use this adapter?
if there, could you post it here, please
Expect, the Unexpected
PostPosted: October 4th, 2021, 12:05
Settings and information how to set for correct readout in FE, PC3K or VNR are delivered with adapter
If you purchased and got any issue with connection just contact at technika@multi-com.pl with your adapter Serial Number
Best regards,
Boguslaw Rzepka,
