 Post subject: USB to SATA probe PCB: FDD UTS PC-3000 series adapter
PostPosted: September 30th, 2021, 3:13
USB to SATA probe PCB: FDD UTS PC-3000 series adapter , currently has the following 7 models:
1:PC-3000 for WD USB 800067
2:PC-3000 for WD USB 800069
3:PC-3000 for WD USB 810003
4:PC-3000 for WD USB 810012
5:PC-3000 for WD USB 810033
6:PC-3000 for WD USB 810035
7:PC-3000 for WD USB 800041
used for data recovery and electronic forensics of Western Digital USB HDD!
This PCB-FHDD UTS has its advantages:
No need to solder wires for Original PCB of patient HDD , But data can read , This method will not damage the original PCB and just remove 4 capacitors that will improve data security, The new test point PCB of HDD is small in size, not easy to Welding wires, The USB PCB of patient HDD to Soldering wires with new young engineers is difficult and has a very high risk of easily damaging the PCB!!!
FHDD UTS itself is not a decryption board, it can be combined with a USB decryption board to form a SATA decryption board.
Check us out at http://www.jundacheng.com/bbs/forum.php ... d&tid=6047
Click to watch the video:https://youtu.be/F5PEmSks7t8
Order now; welcome to consult! Pay with Paypal!
If you are interested,Contact us via Skype:+8617319153943.
Produced by Beijing JunDaCheng Technology Company Limited.Piracy is strictly prohibited。
Beijing Jundacheng Technology Company Limited.
Website:http://www.jundacheng.com/bbs/forum.php?mod=viewthread&tid=6047
 Post subject: Re: USB to SATA probe PCB: FDD UTS PC-3000 series adapter
PostPosted: January 8th, 2022, 3:57
Nowadays we have made some improvements for the PCBs to make it more safe and stable,we also added the ROM read function,which is really convenient to allow you read ROM through the USB to SATA probe PCB directly.Also added new models.
PostPosted: January 20th, 2022, 20:48
Support connection of ROM chip, no need to solder the chip, you can read the ROM through the programmer, and then use the PC-3000 to write to unlock-PCB
1:PC-3000 for WD USB 800067 [ Support Express/UDMA/portable,Support ROM]
2:PC-3000 for WD USB 800069 [ Support Express/UDMA/portable,Support ROM]
3:PC-3000 for WD USB 810003 [ Support Express/UDMA/portable,Support ROM]
4:PC-3000 for WD USB 810012 [ Support Express/UDMA/portable,Support ROM]
5:PC-3000 for WD USB 810033 [ Support Express/UDMA/portable,Support ROM]
6:PC-3000 for WD USB 810035 [ Support Express/UDMA/portable,Support ROM]
7:PC-3000 for WD USB 800041 [ Support Express/UDMA/portable,Support ROM]
8: PC-3000 for WD USB 810086 [Support Express/UDMA/portable ,Support ROM]
