Page 1 of 2
usb to sata adapter without soldering
Posted: September 13th, 2022, 3:26
by wengjieshan
Hi everyone ,
WD adapter plus New version of the PC-3000 can do all WDSMR 2.5" families without unlocked PCB , help you decryt data .
1. Fast delivery
2. Good quality.
3. clients told me adapter is very useful!
Re: usb to sata adapter without soldering
Posted: September 13th, 2022, 13:07
by Setlec
Does it, also, work with rapidspar?
paying it forward
Posted: October 5th, 2022, 11:36
by MrAndersons
I can recommend the quality and reliability of Mr. Wengs products. It has been said that the solderless PCB is not reliable but I have quality tested these boards and upon removing the required caps they work nicely on most modern usb native WD drives (spyglass 2, 3). I also have used his PCB for direct soldering method which I prefer in some cases. I have tested direct wire and solderless to find the same result in most cases. He also sells unlocked boards. Reliable, friendly and fast shipping.
Hope this helps with finding reliable PCBs for some of you who may need guidance.
Posted: October 5th, 2022, 12:52
by MrAndersons
I forgot to mention that on Portable 3 you should direct wire rather than using the solderless PCB.
Posted: October 6th, 2022, 5:36
by Setlec
MrAndersons wrote:I forgot to mention that on Portable 3 you should direct wire rather than using the solderless PCB.
Thank you for your posts they are very instructive. But the solder-less PCB seems a more easier option for me since I've got no skills nor equipment to do macro & micro soldering. Also i've only got a rapidspar from deepspar.
Posted: October 6th, 2022, 7:20
by higgsboson
wengjieshan wrote:Hi everyone ,
1. Fast delivery
2. Good quality.
Can you pls. give your website and other product details. I am looking for PC3000 USB 3.0 Terminal and POGO EEprom Reading probe.
Posted: October 6th, 2022, 10:47
by ddrecovery
1. Fast delivery
2. Good quality.
https://www.jundacheng.com/bbs
Posted: October 6th, 2022, 23:03
by wengjieshan
I mainly do data recovery , but I am still selling unlocked PCB and adapter without soldering . don't sell other products .
Posted: October 7th, 2022, 2:18
by higgsboson
1. Fast delivery
2. Good quality.
This website is not working and is not secure for purchase. Do they have standard purchase platforms like ebay /amazon or alibaba etc.
Posted: October 7th, 2022, 9:02
by wengjieshan
Hi ,
Please contact me by skype :jieshan.weng or Facebook :https://www.facebook.com/datarecoveryChina
thank you !
by MrAndersons
You can just contact him direct and pay through PayPal.
I've had problems in the past finding these boards and he is a reliable source.
Posted: October 7th, 2022, 10:06
by Arch Stanton
Posted: October 7th, 2022, 22:49
by wengjieshan
Adapter without soldering , our is original , the others are all replicates(quality is bad ), pin is different .
Skype:jieshan.weng
Ph(whatsapp):+8613764461998
www.datarecovery-china.com
Posted: October 9th, 2022, 7:57
by xgkj
The UTS probe board only needs simple settings and fully supports ACE UDMA EXPRESS SAS PORTABL 3
Posted: October 9th, 2022, 18:57
by MrAndersons
It did not work when testing with portable 3, direct wire worked. On UDMA it works fine.
Posted: October 11th, 2022, 3:13
by kash
I bought usb to sata adapters for Jieshan weng sir , the product quality is very good and works good . The pogo pin quality is best compared to other boards which are available in our markets . He sends quick delivery on DHL & accepts paypal so its easy and reliable to pay and get the goods on time .
Posted: October 13th, 2022, 23:19
by wengjieshan
Skype:jieshan.weng
http://www.datarecovery-china.com
Posted: October 15th, 2022, 4:09
by Tawfeek
wengjieshan wrote:Adapter without soldering , our is original , the others are all replicates(quality is bad ), pin is different .
Skype:jieshan.weng
Very good quality . i use both wire and Adapter without soldering from jieshan.weng
Posted: October 27th, 2022, 2:14
by wengjieshan
Hi Friends,
Some friends ask me how to recover data from disk with 810033 and 810035 PCB.
Now share my practice
1. Use ROM Reader to read ROM
2. Use unlocked PCB to backup FW
3. Use adapter without soldering to recover data
Posted: October 28th, 2022, 1:57
by chipsang
wengjieshan wrote:Hi Friends,
dear wengjieshan
Your products are indeed superior having very good build quality.
Can you pls. suggest in circuit POGO rom reader for desktop/ laptop rom reading. ( or best quality pogo clips )
Lately I am finding its diffcult to work on desoldering.
Pls. give purchase link as well.
Thanks.
