| New UFD NAND adapters - UP07, UP08, UP09, UP10 !!! http://forum.hddguru.com/viewtopic.php?f=15&t=42864 |
Page 1 of 1 |
| Author: | Bolo [ November 14th, 2022, 8:21 ] |
| Post subject: | New UFD NAND adapters - UP07, UP08, UP09, UP10 !!! |
Hello guys, Next project is finished - this time 4 new MR adapters for NAND UFD !!!! Adapter is compatible with devices from companies such as Visual NAND Reconstructor, i.e. VNR (Rusolut), Flash Extractor (Soft Center) and PC3000 Flash (Ace Laboratory) Monolithic UFD flash drive MR UP07 NAND adapter for Kingston DT Micro series ![]() ![]() ![]() ![]() Supported memory: ![]() Monolithic UFD flash drive MR UP08 NAND adapter for Kingston DT Micro series ![]() ![]() ![]() ![]() Supported memory: ![]() Monolithic UFD flash drive MR UP09 NAND adapter for Kingston DT Micro series ![]() ![]() ![]() ![]() Supported memory: ![]() Monolithic UFD flash drive MR UP10 NAND adapter for Kingston DT Micro series ![]() ![]() ![]() ![]() Supported memory: ![]() You can buy all of those here - https://multi-com.eu/,,smenu,forensic_tools.html Don't miss to check all available adapters at https://multi-recovery.com/models.php |
