Flash Extractor Reader Low Voltage Modification Patch
http://forum.hddguru.com/viewtopic.php?f=15&t=43518
Author:  csava [ July 27th, 2023, 4:47 ]
Post subject:  Flash Extractor Reader Low Voltage Modification Patch
https://www.youtube.com/watch?v=eIFhLcDbNi0&t=8s
The principle behind this patch is to modify the perception capability of the Reader unit towards low voltage signals, rather than relying on an external level-shifting chip. About six months ago, I attempted to address reading VCCQ 1.8-1.2 Low VCCQ NAND Flash by creating additional adapters. However, on certain chips, this approach significantly reduced the reading quality. I cannot tolerate such results, so despite producing dozens of these adapters in small batches, they are all sitting unused in a corner now. The current solution I have developed is the best one I have tried so far. With the modified Reader, certain chips like 45 3C 98 B3 achieve a more stable dump quality compared to the original Reader.
If you are interested in this patch, you can find it on my website.
Author:  Gregory [ July 27th, 2023, 14:00 ]
Post subject:  Re: Flash Extractor Reader Low Voltage Modification Patch
This is very cool mod, but I see that it is required to desolder the FPGA and solder again. If it's work that good news :) I quick check and this old Altera Cyclone also use 1,5V and 2,5V for VCCIO, saddy no 1.2V - this voltage is support form Cyclone III :( But if only 1.8V do the work, I am interested in this modification.
Author:  mayanksharmaggc [ December 18th, 2023, 14:08 ]
Flash extractor power adapter v3 required
