 Post subject: MT NOR Adapter for MediaTek 2503DV SoC !!!
PostPosted: October 30th, 2023, 5:00
MT NOR Adapter for MediaTek 2503DV SoC is a programmer in the form of a USB key that allows access to data contained in the internal NOR memory embedded in MediaTEK (MTK) 2503DV SoC. These processors (SoC) are most often found in budget phones, the so-called Features phones, GPS trackers and smartwatches. Due to the lack of an SPI or I2C access protocol, the only possibility of accessing the data after a device failure (e.g. breaking the motherboard to prevent access) was to perform a chip SWAP to a functional device. Our adapter revolutionizes data recovery from such cases - just after ChipOFF, place the processor in the adapter and connect the adapter to the USB to enable data reading.
Features:
- physical reading of NOR memory directly from ALL processors based on MTK 2503DV (e.g. damaged devices) regardless of the manufacturer
- reading deleted Messages, Lists of calls made, Contacts using appropriate investigative software (tested on Cellebrite UFED, MSAB XRY)
- making a full flash copy in order to transfer the content to another device of the same type (duplicate)
- programming of empty processors directly in the adapter without having to allocate the chip in the decel device
Order link - https://multi-com.eu/,details,id_pr,22958.html
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
