 Post subject: Monolithic UFD MR UP11 NAND adapter for Samsung Type-C serie
PostPosted: January 4th, 2024, 8:57
Monolithic UFD flash drive MR UP11 NAND adapter for Samsung Type-C series is high quality special adapter for memory flash drive using NAND protocol without soldering. The MR UP11 adapter is compatible with devices such as Visual NAND Reconstructor VNR (Rusolut), Flash Extractor (Soft Center) and PC3000 Flash (Ace Laboratory). The adapter replaces the need for any soldering to the card for reading and, thanks to unique solutions, it also enables quick XOR extraction or analysis and configuration of other pinouts than originally provided with the adapter using a logic analyzer. Use of the adapter minimizes the risk of card damage by soldering (ie pad breaking) and faster readings in microSD card technology mode using various NAND programmers.
THIS DEVICES CAN BE 100% SOLVED WITH STRUCTURE
Specification:
- made from solid monolith block of TecaFORM-H made in Germany and brushed aluminum for durability.
- specially developed PCB tracks routing technology to prevent interference during NAND reading
- special high quality pogo contact pins used which are used for specialized laboratory tests
- ready to work on standard pinout (pinout delivered with adapter) as well as alternative one by special sockets
- MR adapter can be connected via mini USB for faster XOR analysis and extraction (look move below)
- MR adapter can be connected to any LA (Logic Analyzer) to analyze signals and find custom pinouts without need of soldering
- short circuit protection build-in to avoid demage of NAND from 5V USB rail
Compatible with devices of world leaders in data recovery:
- Visual NAND Reconstructor (VNR) - Rusolut
- PC3000 Flash (Ace Laboratory)
- Flash Extractor (Soft Center)
Support monolith for USB Samsung (MUF) Type-C series:
- model 64GB 1 channel 1xCE
- model 128GB 2 channels 1xCE
- model 256GB 2 channels 2xCE
Complete contains:
- UFD Monolithic MR UP11 NAND adapter
- selected adapter for 1 of the listed devices ie VNR, PC3000 or FE (additional adapters can be purchased in addition)
- 1 set of connection FF cables
- instruction with full pinout (for two channels)
- warranty card
YOU CAN ORDER YOURS AT https://multi-com.eu/shrt-szJ3qFrh
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
