Post new topic Reply to topic  [ 103 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
 Post subject: ER-Tools - new simple head stack replacement tools
PostPosted: August 5th, 2013, 9:06
Hello everyone!
I would like present a new simple type of hard drive head stack replacement tool. This tool made from strong acrilyc sheet with high precision accuracy at 0.01 mm. By using this tool heads are can be safely lifted off from surface and then moved outside the platters absolutely without touching surface. Tool also do not touch the surface too. Of course light touch of the surface by the tool will be inevitably while setting or removing tool process, but platters are don't have new defects after that. It's proved in many experiments!
Some images below.
Original 3D model has self-fixed micro-holders to prevent tool falling out:
Real products in real data recovery process:
For more information or any questions regarding purchasing visit our web site: er-tools.com
P.S. Sorry for my bad english, foreign languages isn't my strong side :)
Best regards,
ER-Tools lead developer,
Alexander Erofeev.
Khabarovsk, Russia.
mailto: info@er-tools.com
skype: er-tools
 Post subject: Re: ER-Tools - new simple head stack replacement tools
PostPosted: August 5th, 2013, 21:19
Machining looks really good, although with this design I would be afraid of the tool falling out while pulling the headstack out. Seems like it would work better if it were fixed to a pivot point (like another tool out there - although that might some patent laws, etc.)
PostPosted: August 5th, 2013, 22:56
it looks a good tool i dont think the head would fall out as its got a little catch to stop it from shifting
the qeastion is how good is plastic vs metal versions.
and how well does the tool work
ok check out the website cheap for sure :)
PostPosted: August 6th, 2013, 4:59
Hi
I think it would be great to see some videos of you testing the tools, to see how they work.
The thing of not getting fixed could be a problem....
ACELab partner
PostPosted: August 6th, 2013, 6:01
It's always interesting to see new tools and ideas coming into DR...... I think though, it's a "Suck it and See" tool.... you're gonna have to give it a try to see if you like it..... :D
East Anglian Data Recovery Services
http://www.eadr.co.uk
"If it's your only copy - then it's not a backup!"
PostPosted: August 6th, 2013, 6:27
Thanks for reply. I'll make some videos soon. :wink:
My tools is result of hard work and many experiments. It started at december 2012 and now, after half year, commercial versions of the tools in sale. Work report was published at pc-3000 support forum, you can see it there (if you have access).
Of course tool not ideal, and it has one huge negative moment - in setting/removing tool process you can touch the surface. BUT! Because material is plastic and machined with high accuracy, after light touching of the platters they not have new bad sectors.
And then tool is finally fixed you can safely move HSA to non-data area without any touching MR-heads or plastic tool with surface.
This way is more carefully then other plastic tools like these:
For example, if you need to exchange heads in high density drive such as ST3500418AS or ST31500340AS, tools on the picture above just kill HSA after moving heads over the surface from landing zone in 90% cases. With my tools this job is pretty eazy and effective. And of course low price of the tool is positive moment too. 8)
Best regards,
Alexander Erofeev.
Khabarovsk, Russia.
skype: er-tools
PostPosted: August 6th, 2013, 7:42
I like your website.
The tools seem well machined and of high quality for using plastic materials. I like the labeling on the tool itself. Very handy.
Prices seem reasonable.
I am low on budget at this time, but may get some later on.
PostPosted: August 8th, 2013, 13:50
Hello guys,
Do any one tried this tools already?
PostPosted: August 8th, 2013, 19:39
I need a video before even considering these tools. A clean and close up good quality video. Without that, I'm stuck with the idea in my head that these head tools will slip off or even damage the heads/platters. Don't knock the SD head combs, there the only useful tools SD has produced. :mrgreen:
PostPosted: August 9th, 2013, 5:30
I just buyed this:
http://en.er-tools.com/catalog/item/12
I will try it when i will receive the EMS package
My firmware database:
PostPosted: August 9th, 2013, 6:08
Great. Send us your feedback about them as soon you tried them.
PostPosted: August 9th, 2013, 11:04
Yeah, if possible, post a video.
ACELab partner
PostPosted: August 10th, 2013, 9:01
Finally I did some short videos, you can see it in YouTube!
http://www.youtube.com/watch?v=-972i020Xvs
http://www.youtube.com/watch?v=pI2xmWIp0DE
Sorry guys for low video quality, I'll try to make better videos few time later.
Best regards,
Alexander Erofeev.
Khabarovsk, Russia.
skype: er-tools
PostPosted: August 11th, 2013, 4:43
hey that a good video
yes your tool looks good and you can see that the tool can not come away that easy.
so no damaging the headstacks.
PostPosted: August 11th, 2013, 8:37
Thanks for the video :)
PostPosted: August 11th, 2013, 16:50
Thanks for the video, makes me think I might even be able to change a headstack ;)
PostPosted: August 12th, 2013, 2:52
I like the moust labeling of the tools :)
Taking them off could be a problem I beleive.
HddSurgery - Professional Data Recovery Tools
PostPosted: August 12th, 2013, 3:00
I bought 7200.11/.12/ES.2/LP 2D (Ver.4)
He added as a gift F1/F2/F3 Samsung 1D (Ver.4)
http://en.er-tools.com/catalog/item/2
:D
PostPosted: August 12th, 2013, 12:55
The insertion of the tool seems a little bit hard not to damage the platters...
I think it still needs to practice allot to get the job done.
But for the price we can't ask much more.
The tools of HDDsurgery seems better (tough I never test them). This is only by seeing the videos, I would like to test them in hands ehehehe
ACELab partner
PostPosted: August 12th, 2013, 21:37
Yes, you are absolutely right. Before use tools in real data recovery cases you must to try it on your own another hard drives - totally broken or partly worked. You must to feel all important moments - angles, directions, forces etc. After that with some experience head swap will be really easy and safely for user data.
Users browsing this forum: No registered users and 72 guests
