 Post subject: NEW ASR NOR Adapter for ASR 3603 SoC is AVAILABLE
PostPosted: September 18th, 2024, 7:14
Some special for iOT devices, watches and GPS devices ;)
ASR NOR Adapter for ASR 3603 SoC is a programmer in the form of a USB key that allows access to data contained in the internal NOR memory embedded in ASR 3603 SoC. These processors (SoC) are most often found in smartwatches, GPS trackers and IoT devices. Our adapter revolutionizes data recovery from damaged devices - just after ChipOFF, place the processor in the adapter and connect the adapter to the USB to enable data reading.
Features:
- physical reading of NOR memory directly from ALL processors based on ASR 363 (e.g. damaged devices) regardless of the manufacturer
- making a full flash copy in order to transfer the content to another device of the same type (duplicate)
- programmer based on the CH341A chip, the content can be read with free software, e.g. CH341A Programmer 1.29
NOTE: The built-in NOR chip in the ASR 3603 processor is GIGADEVICE DS25Q128, and this chip should be selected when reading
More info at https://multi-com.eu/shrt-4iliaIxiY
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
