 Post subject: New MR eMMC NAND adapters for BGA 254 available !
PostPosted: February 14th, 2025, 11:21
Helo guys,
We want to present you our new project - MR NAND adapter for eMMC / eMCP memory - MR TYPE 26 (Samsung BGA254) and MR NAND adapter for eMMC / eMCP memory - MR TYPE 25 (Samsung BGA254) !!
MR NAND adapter for eMMC / eMCP memory - MR TYPE 26 (Samsung BGA254) is high quality special adapter for eMMC flash memory using NAND protocol without soldering. The MR adapter is compatible with devices such as Visual NAND Reconstructor VNR (Rusolut), Flash Extractor (Soft Center) and PC3000 Flash (Ace Laboratory). The adapter replaces the need for any soldering to the card for reading and, thanks to unique solutions, it also provides quick analysis and configuration other pinouts using a logic analyzer. Use of the adapter minimizes the risk of flash chip damage by soldering (ie pad breaking) and instantly reading using various NAND programmers.
Supported eMMC chip:
Specification:
- made from solid monolith block of TecaFORM-H made in Germany and brushed aluminum for durability.
- printed circuit made with the highest precision of 4mils and gold plated pads to minimize interference
- specially developed PCB tracks routing technology to prevent interference during NAND reading
- special high quality pogo contact pins used which are used for specialized laboratory tests
- ready to work witch many pinouts by special sockets
- different cards size support by special inners
- built-in additional noise filters to prevent "noise" during NAND readings
- MR adapter can be connected to the SD card reader for initialization memory
- MR adapter can be connected to any LA (Logic Analyzer) to analyze signals and find custom pinouts without need of soldering
Compatible with devices of world leaders in data recovery:
- Visual NAND Reconstructor (VNR) - Rusolut
- PC3000 Flash (Ace Laboratory)
- Flash Extractor (Soft Center)
Supported models:
- H9HP52AC8PMMD
Photos of the adapter:
Available socket (pinouts):
More information: https://multi-com.eu/shrt-FpB4BsEFc
MR NAND adapter for eMMC / eMCP memory - MR TYPE 25 (Samsung BGA254) is high quality special adapter for eMMC flash memory using NAND protocol without soldering. The MR adapter is compatible with devices such as Visual NAND Reconstructor VNR (Rusolut), Flash Extractor (Soft Center) and PC3000 Flash (Ace Laboratory). The adapter replaces the need for any soldering to the card for reading and, thanks to unique solutions, it also provides quick analysis and configuration other pinouts using a logic analyzer. Use of the adapter minimizes the risk of flash chip damage by soldering (ie pad breaking) and instantly reading using various NAND programmers.
Specification:
Supported models:
- KMDV6001DB
- KMDH6001DA
More at https://multi-com.eu/shrt-aDrZ8bXb
Want to get see other adapters ? Check our page at https://multi-recovery.com/
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
 Post subject: Re: New MR eMMC NAND adapters for BGA 254 available !
PostPosted: February 15th, 2025, 10:14
Bolo wrote:
Helo guys,
Error - schould be
Bolo wrote:
Helo guys,
We want to present you our new project - MR NAND adapter for eMMC / eMCP memory - MR TYPE 26 (Hynix BGA254) and MR NAND adapter for eMMC / eMCP memory - MR TYPE 25 (Samsung BGA254) !!
Best regards,
Boguslaw Rzepka,
