 Post subject: New MicroSD NAND Monolithic MR24 V2 adapter (diagram 6x4)
PostPosted: March 5th, 2026, 11:22
NEW VERSION WITH UPDATED RASTER 6x4 IS AVAILABLE !
MicroSD NAND Monolithic MR24 V2 adapter (diagram 6x4) is high quality special adapter for microSD cards with 6x4 pitch using NAND protocol without soldering. The MR24 V 2adapter is compatible with devices such as Visual NAND Reconstructor VNR (Rusolut), Flash Extractor (Soft Center) and PC3000 Flash (Ace Laboratory). The adapter replaces the need for any soldering to the card for reading and, thanks to unique solutions, it also enables quick XOR extraction or analysis and configuration of other pinouts than originally provided with the adapter using a logic analyzer. Use of the adapter minimizes the risk of card damage by soldering (ie pad breaking) and faster readings in microSD card technology mode using various NAND programmers.
Compatible with devices of world leaders in data recovery:
- Visual NAND Reconstructor (VNR) - Rusolut
- PC3000 Flash (Ace Laboratory)
- Flash Extractor (Soft Center)
Photos of products:
Prepared to work on the standard and modified 6x4 raster (in new raster there is diffrent pin location and signals on pads)
Works with microSD card which uses 6x4 pitch (col/row) - included standard pinout for the card below
And with new 6x4 rasters:
An example of a mounted MR adapter (example MR24) on a PC3000 Flash
https://multicomeu-a9bf.kxcdn.com/multi ... r_600B.jpg
Example of mounted MR adapter (on MR24 example) in VNR device
https://multicomeu-a9bf.kxcdn.com/multi ... r_600C.jpg
Set contains:
- Adapter for monolithic microSD cards - MR24 V2 (Raster 6x4)
- Alternative pinout MR24 V2 AP1
- selected adapter for 1 of the listed devices ie VNR, PC3000 or FE (additional adapters can be purchased in addition)
- 1 x connection PCB for microSD -> SD
- 1 set of FF connection cables for LA / Custom pinout
- User manual with standard pinout for 6x4 raster and alternative pinout
- Warranty Card
Warranty
On the adapter we give 36 months of warranty.
More informations - https://multi-recovery.com/
Order at https://multi-com.eu/shrt-LqvpAo3yD
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
 Post subject: Re: New MicroSD NAND Monolithic MR24 V2 adapter (diagram 6x4
PostPosted: March 16th, 2026, 9:39
36 months warranty! Like it! :D
Users browsing this forum: Google [Bot] and 15 guests
