 Post subject: BGA199 MR adapter v2 available !!!!
PostPosted: October 16th, 2026, 7:15
SD/NAND MR BGA199 V2 Adapter is high quality special adapter for BGA199 chips using SD/eMMC or NAND protocol without soldering. The MR BGA199 V2 adapter is compatible with devices such as Visual NAND Reconstructor VNR (Rusolut), Flash Extractor (Soft Center) and PC3000 Flash (Ace Laboratory).
Specification:
- made from solid monolith block of TecaFORM-H made in Germany and brushed aluminum for durability.
- printed circuit made with the highest precision of 4mils and gold plated pads to minimize interference
- specially developed PCB tracks routing technology to prevent interference during NAND reading
- special high quality pogo contact pins used which are used for specialized laboratory tests
Compatible with below products for NAND reading:
- Visual NAND Reconstructor (VNR) - Rusolut
- PC3000 Flash (Ace Laboratory)
- Flash Extractor (Soft Center)
Foto of MR BGA199 V2 adapter:
More at http://multi-com.eu/,details,id_pr,23570.html
P.S
We have also addedd into order set of BGA 199 which support both versions - v1 and v2
This can be found at https://multi-com.eu/,details,id_pr,23571.html
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
