 Post subject: Donor needed WD1200BB-00CAA1 DCM:HSEHCT2CH
PostPosted: August 1st, 2026, 7:13
I am looking for a donor drive for a head swap and hope you can help me find a match.
PATIENT
Model:        WD1200BB-00CAA1
DCM:          HSEHCT2CH
Serial:         WMA8C3308641
PCB label:    2061-001092-300 J
Date:         11 DEC 2002
The critical identifiers are highlighted
For DCM I found two sources - I would try both - or maybe you have other information?
DCM:          HSEHCT2CH
or
DCM:          HSEHCT2CH
 Post subject: Re: Donor needed WD1200BB-00CAA1 DCM:HSEHCT2CH
PostPosted: August 5th, 2026, 18:44
a simple head swap will most likely not work, even with matching dcm.
PostPosted: August 5th, 2026, 19:58
Can you upload the patient and donor ROMs? In a previous case I transferred the head adaptives from donor to patient, and this enabled the DIY-er to recover "unreadable" sectors. Perhaps it might help in your case.
