| Donor needed WD1200BB-00CAA1 DCM:HSEHCT2CH http://forum.hddguru.com/viewtopic.php?f=15&t=46205 |
Page 1 of 1 |
| Author: | BenKo44 [ August 1st, 2026, 7:13 ] |
| Post subject: | Donor needed WD1200BB-00CAA1 DCM:HSEHCT2CH |
Hello, I am looking for a donor drive for a head swap and hope you can help me find a match. PATIENT Model: WD1200BB-00CAA1 DCM: HSEHCT2CH Serial: WMA8C3308641 PCB label: 2061-001092-300 J Date: 11 DEC 2002 The critical identifiers are highlighted Model: WD1200BB-00CAA1 Serial: WMA8C3308641 For DCM I found two sources - I would try both - or maybe you have other information? DCM: HSEHCT2CH or DCM: HSEHCT2CH Thanks |
| Author: | pepe [ August 5th, 2026, 18:44 ] |
| Post subject: | Re: Donor needed WD1200BB-00CAA1 DCM:HSEHCT2CH |
a simple head swap will most likely not work, even with matching dcm. |
| Author: | fzabkar [ August 5th, 2026, 19:58 ] |
Can you upload the patient and donor ROMs? In a previous case I transferred the head adaptives from donor to patient, and this enabled the DIY-er to recover "unreadable" sectors. Perhaps it might help in your case. |
