| ...and the drives I am seeing the most in for recovery... http://forum.hddguru.com/viewtopic.php?f=15&t=8299 |
Page 1 of 1 |
| Author: | Odiferous [ January 2nd, 2008, 15:35 ] |
| Post subject: | ...and the drives I am seeing the most in for recovery... |
.... are Seagate. Especially those manufactured after mid-2007, with larger capacities. (3.5" drives.) Bearing seizure, head failures - only two years ago Seagate used to be the most reliable. Now I see more of those than WD and original Maxtor put together. Anyone else have some comments? |
| Author: | dmarques [ January 3rd, 2008, 4:55 ] |
| Post subject: | Re: ...and the drives I am seeing the most in for recovery... |
I have seen that as well. I have received a lot of Seagate from 320 to 750 Gb with damaged heads, bearing and even head crashes. |
| Author: | dobrevjetser [ January 3rd, 2008, 5:30 ] |
Same for me; lots of seagates, mostly with bearing problems. Dobre |
| Author: | stt [ January 3rd, 2008, 6:26 ] |
Are the labels plain white or do they have a green line around the outside? |
| Author: | Odiferous [ January 3rd, 2008, 10:09 ] |
No green line / RMA drives seen recently - only originals. |
| Author: | rameez [ January 11th, 2008, 14:47 ] |
Same here Seagate , there is a reason why seagate are seen much in cases because they sold most unlike WD and Maxtor . |
| Author: | Odiferous [ January 13th, 2008, 5:06 ] |
rameez wrote: Same here Seagate , there is a reason why seagate are seen much in cases because they sold most unlike WD and Maxtor . I doubt it, Rameez. Even if Seagate sold three times as many drives as WD and the old Maxtor, I'm still seeing more than three Seagates for every WD / Maxtor that comes in. Also, because they are almost all displaying the same problem, this leads me to believe they are having production / design problems. Get manufacturing out of China, charge the end user an extra $2 per drive - problem solved. Duncan |
