 Post subject: Donors Needed
PostPosted: January 7th, 2008, 21:31
I'm in need of the following donor drives :
1. Wd Scorpio Sata Laptop drive
WD1200B EVS - 22RST0
DCM :HBCTJANB
DATE 02 MAR 07
Need for heads
2.Seagate Barracuda ATAIII
ST320414A
Firmware # 3.05
Date Code 0129
Site Code ML2
Need board
3.Wd Caviar pata
WD400BB-00DKA0
Date 17 Aug 2003
DCM: HSCHCVJAA
Need board
 Post subject: Re: Donors Needed
PostPosted: January 8th, 2008, 6:10
On the WD400BB - what is the number printed on the board? Probably begins 2060-
Duncan
PostPosted: January 8th, 2008, 6:20
2060-001159-006 imprinted on pcb
2061-001159-100EB on label
board has a notch next to screw hole by ide connection
which other boards don't have
(salvation calls this a silver II series)
PostPosted: January 8th, 2008, 6:37
I got a 2060-001159-006 if you want to borrow it.
Like you say, it's got a little notch by the IDE screw hole.
MSN me if you like. ;-)
Cheers
Sean
PostPosted: January 9th, 2008, 18:12
Sean check pm
PostPosted: January 9th, 2008, 19:36
Anyone on these other 2 drives?
PostPosted: January 11th, 2008, 14:50
If u still need the wd400bb drive u can PM me .
