| Donors Needed http://forum.hddguru.com/viewtopic.php?f=15&t=8329 |
Page 1 of 1 |
| Author: | Steve [ January 7th, 2008, 21:31 ] |
| Post subject: | Donors Needed |
I'm in need of the following donor drives : 1. Wd Scorpio Sata Laptop drive WD1200B EVS - 22RST0 DCM :HBCTJANB DATE 02 MAR 07 Need for heads 2.Seagate Barracuda ATAIII ST320414A Firmware # 3.05 Date Code 0129 Site Code ML2 Need board 3.Wd Caviar pata WD400BB-00DKA0 Date 17 Aug 2003 DCM: HSCHCVJAA Need board |
| Author: | Odiferous [ January 8th, 2008, 6:10 ] |
| Post subject: | Re: Donors Needed |
On the WD400BB - what is the number printed on the board? Probably begins 2060- Duncan |
| Author: | Steve [ January 8th, 2008, 6:20 ] |
2060-001159-006 imprinted on pcb 2061-001159-100EB on label board has a notch next to screw hole by ide connection which other boards don't have (salvation calls this a silver II series) |
| Author: | pcimage [ January 8th, 2008, 6:37 ] |
I got a 2060-001159-006 if you want to borrow it. Like you say, it's got a little notch by the IDE screw hole. MSN me if you like. Cheers Sean |
| Author: | Steve [ January 9th, 2008, 18:12 ] |
Sean check pm |
| Author: | Steve [ January 9th, 2008, 19:36 ] |
Anyone on these other 2 drives? |
| Author: | rameez [ January 11th, 2008, 14:50 ] |
If u still need the wd400bb drive u can PM me . |
