| Donor needed: WD5000KS-00MNB0, HCACAJAAA http://forum.hddguru.com/viewtopic.php?f=15&t=8368 |
Page 1 of 1 |
| Author: | arturk [ January 14th, 2008, 11:55 ] |
| Post subject: | Donor needed: WD5000KS-00MNB0, HCACAJAAA |
Hello, I'm need donor drives for my broken WD drive: MDL: WD5000KS-00MNB0 DCM: HCACAJAAA WWN: 50014EE055579D8A PCB Part#: 2060-701383-001 REV A Any help would be appreciated. Artur |
| Author: | arturk [ January 14th, 2008, 16:34 ] |
| Post subject: | Re: Donor needed: WD5000KS-00MNB0, HCACAJAAA |
Does anyone know how to figure out firmware version from stickers on hardrive? I cannot find it anywhare and since drive is now dead this might be only option. |
| Author: | mdin [ March 28th, 2008, 7:02 ] |
did you manage to fix this problem? I have the same problem and need help with data recovery |
| Author: | arturk [ March 28th, 2008, 13:27 ] |
No, I was not able to find donor and after talking to some people and reading on this forum I concluded it was not PCB problem. I did not want to atempt to do anything with heads and I do not have tools to fix firmware. Also, data was not that important to me so I gave up and send it WD for warranty replacement. Good luck! |
| Author: | martcom [ April 2nd, 2008, 12:34 ] |
Hello We have used parts and pcb boards for hard drives mail for parts If we have i will try to help with parts |
