 Post subject: Seagate ST3120023AS - 9W2813-301 - Need PCB
PostPosted: March 18th, 2008, 13:32
I have a
Seagate 7200.7 120GB SATA
Model: ST3120023AS
P/N: 9W2813-301
Site Code: AMK
Firmware: 3.05
Need PCB and advice.
Thanks in advance
 Post subject: Re: Seagate ST3120023AS - 9W2813-301 - Need PCB
PostPosted: March 19th, 2008, 15:12
I have the pcb PM me for further info . Also tell me your location in pm
PostPosted: April 2nd, 2008, 12:32
Hello
We have used parts and pcb boards for hard drives mail for parts
If we have i will try to help with parts
chester@martcom.com
Hard drives from 10Mb to 2Tb MFM/RLL/SCSI/IDE/SATA/PATA/SAS
DRIVES / PCB / BOARDS
PostPosted: April 10th, 2008, 20:11
Anyone?
neoborn wrote:
rameez wrote:
HDA is the part without the PCB . There is one way u can check the motor if u have a multimeter switch it to diode mode and check on the 1 and second pin and 2 and 3 pin there values should be .2 ohms .
If not then motor is bad no need for the PCB . else PCB is faulty replacing it will solve ur problem .
Are you saying to check P1 & P2, then P2 & P3 and it should read 2 ohms? I did test those on that setting and it read 0.07 on the 2000 or 20k setting
PostPosted: April 15th, 2008, 14:42
The pins are on the motor .
