Samsung SP0812C star and down
http://forum.hddguru.com/viewtopic.php?f=15&t=8880
Author:  steve67890 [ April 22nd, 2008, 13:03 ]
Post subject:  Samsung SP0812C star and down
I have a Samsung hdd SP0812C F/W100-32, the hdd run 5 or 6 secunds and stop, What problem could has my hdd ? I need a comments for repair my hdd, This problems is a PCB or Damaged on the media ?
Steve
Author:  dmarques [ April 23rd, 2008, 4:38 ]
Post subject:  Re: Samsung SP0812C star and down
It can be a lot of things.
Have you swapped the pcb and check results?
Have you checked terminal report?
Author:  steve67890 [ April 23rd, 2008, 4:52 ]
Yes I change the PBC for exacly PBC and continue the problem, Is posible that the failure is the plat (Media) ?
Author:  dmarques [ April 23rd, 2008, 11:51 ]
Yes, it's possible.
But can you check terminal ?
Author:  steve67890 [ April 23rd, 2008, 14:30 ]
I plug in other terminal and show the same problems. I thinks that the PBC is failure. !
Author:  rameez [ April 27th, 2008, 14:06 ]
After pluging the terminal u have to see what report it generates that way u can identify the problem .
