HDD GURU FORUMS
http://forum.hddguru.com/
PCB for WD2500BB-00RDA0
http://forum.hddguru.com/viewtopic.php?f=15&t=9349
Page 1 of 1
Author:  GORGIO777 [ July 5th, 2008, 14:59 ]
Post subject:  PCB for WD2500BB-00RDA0
Hi to all. Something happened with the HDD and I need to change the PCB. The details of the HDD are
WD2500BB-00RDA0
DATE: 06 APR 2006
DCM: D8BHCTJAH
PCB: 2061-701292-B00 AA XW 3D03 1RY3 9 0007400 6407
I would appreciate your expert opinions on my problem.
Thank you in advance
Author:  rameez [ July 6th, 2008, 11:51 ]
Post subject:  Re: PCB for WD2500BB-00RDA0
Can u see any visible damage with ur pcb ???
Author:  GORGIO777 [ July 6th, 2008, 14:00 ]
Yes. An IC has been damaged . I think is the spindle IC.
Author:  mr_spokk [ July 7th, 2008, 18:18 ]
Hi, you're right it's spindle motor IC.
And next to it you'll find the 8 legged chip you need to desolder and resolder to the new Pcb you have to buy.
And that Pcb should have the same numbers (2061-701292) on it.
Search for burnt Pcb on the forum, and you get a lot of help.
Regards/ Bosse
Author:  rameez [ July 8th, 2008, 15:48 ]
Most of the times i have seen when this component burns it also damages the fuse R120 , Diode , and one of the transistors , Check them before changing the controller .
http://www.phpbb.com/
