[WANTED] ===Seagate Barracuda 7200.9 ST3300622A 300GB IDE===
http://forum.hddguru.com/viewtopic.php?f=15&t=9356
Page 1 of 2
Author:  hiro [ July 8th, 2008, 0:24 ]
Post subject:  [WANTED] ===Seagate Barracuda 7200.9 ST3300622A 300GB IDE===
I am looking for a ST3300622A drive or PCB board with the following.
I need it for data recovery.
Model: Seagate Barracuda 7200.9 ST3300622A 300GB IDE 16MB cache
P/N: 9BD044-303
Firmware: 3.AAE
Date Code: 06337
Site Code: TK
On the PCB white sticker: 100373052 J 7631D713
If you have one, please contact me I would like to buy it.
Author:  hiro [ July 8th, 2008, 0:50 ]
ST3300622A
This is my PCB board picture.
Author:  pcimage [ July 8th, 2008, 5:11 ]
Post subject:  Re: [WANTED] ===Seagate Barracuda 7200.9 ST3300622A 300GB IDE===
You see the burnt component, bottom left?
Remove it
Author:  hiro [ July 8th, 2008, 7:26 ]
Remove it
Hi, pcimage
If I know the name of Microchip.
I try to change it.
but The chip is burnt, I do not see a model number of chip.
So I looking for a complete PCB board or drive for data recovery.
Author:  pcimage [ July 8th, 2008, 9:11 ]
It's a TVS.
Like I said, remove it ;-)
Author:  rchadwick [ July 8th, 2008, 10:15 ]
Trust the man. :)
Author:  claude77 [ July 10th, 2008, 2:04 ]
Hi Gurus,
I'm a complete newbie at this but it would certainly appear that 'hiro' and I have a similar problem. Mine is a Seagate Barracuda 7200.10, 320GB HD but I've got a similar component burnt out (I think). So what is a TVS and how do I remove it? Also, what is the likely cause of it burning in the first place and what will happen to the board if the fault occurs again without this 'TVS' in place? Like I said, I'm a newbie :? Any help would be appreciated, thanks.
File comment: Close-up of burnt component
File comment: The underside of the hard drive, 'burnt' component circled.
Author:  mr_spokk [ July 10th, 2008, 5:03 ]
claude77 wrote:
Hi Gurus,
Hi, the TSV is a transient voltage suppression (TVS) diode and it take care of any peaks in the current.
And by removeing it you're be able to get your drive running and get your data back (for the short time) If you want the drive to operate longer you're advised to replace it with a new one to protect the other components from another peak.
Notice that the peaks can come from a bad or faulty PSU, so always buy quallity, before quantity :wink:
Regards/ Bosse
Author:  claude77 [ July 10th, 2008, 6:42 ]
Thanks for the swift and helpful reply mr_spokk! It's very much appreciated :) Cheers!
Author:  mr_spokk [ July 10th, 2008, 11:27 ]
You're welcome :wink:
Author:  mmusters [ August 7th, 2008, 15:17 ]
mr_spokk, I have a similar problem. Can I take the drive to an electronics repair place and simply have them remove the TVS diode? Will that enable the drive to spin up? If not, do you know someone I can send the drive to, to have it repaired?
Marty
Author:  sujaypaichar [ August 7th, 2008, 17:03 ]
mr_spokk, Please go through this. Canu help me?? I want to recover the data. So should we have to short the 2 terminals where there was diode or just remove the diode??
post57597.html?hilit=tvs#p57597
Can i get the equivalent diode in IDE???
Author:  rchadwick [ August 7th, 2008, 17:17 ]
Why are three different threads required for one problem?
Author:  pcimage [ August 8th, 2008, 17:09 ]
Just remove the bloody thing!
It will usually work, if it doesn't work straight away then turn it off quickly, there is further damage.
Once you have the data, then throw the drive away.
Author:  wassimb [ September 10th, 2008, 1:15 ]
Guys I also have a problem with my Hdd which also died. My hard disk keeps trying to spin the hd at fixed time intervals. Then after 10-15 tries stops trying. This is the same routine everytime I start it. I also have a damaged/burnt part on my hard disk and I have attached the picture. My damaged part is number 2. What do you think gurus?
Author:  rchadwick [ September 10th, 2008, 2:18 ]
That's a coil likely used for a DC-DC converter. They rarely go bad on their own. I tend to think there's other problems.
Author:  hantymansy [ October 4th, 2008, 13:28 ]
hello! I guess i have the same component burnt on my sata Seagate 7200.9 ST380211AS.
It has the same manufacturer's logo on it
the letters on it:
QE
R617
is it the same thing as QE R610?
I tried to search ON semiconductor website for those letters but with no success. how can I find what part is that?
on the attached foto is that component being unsoldered. I just put it on the place where it should be.
Author:  rchadwick [ October 4th, 2008, 14:29 ]
Are you trying to return the drive to service?
Author:  hantymansy [ October 4th, 2008, 16:36 ]
rchadwick,
no, i'm fixing it by myself. I got that thing burnt on one of my hard drives and I just took it from the similar working HD I had. So now I'm trying to figure out what part is that and where i can get it
Author:  rchadwick [ October 4th, 2008, 17:41 ]
You misunderstood. Are you trying to recover data off the drive, or just use the drive?
Page 1 of 2 All times are UTC - 5 hours [ DST ]
