| WD5000KS-00MNB0, DCM:HCACAJAHB needed http://forum.hddguru.com/viewtopic.php?f=15&t=9402 |
Page 1 of 1 |
| Author: | samppix [ July 13th, 2008, 15:27 ] |
| Post subject: | WD5000KS-00MNB0, DCM:HCACAJAHB needed |
Hi! I have a WD5000KS drive with a dead firmware ROM. So i need a matching drive for spare parts to possibly recover my data. I got this info from HDD recover specialist. My drive specs. Product of Thailand WD5000KS-00MNB0 Date: 28 OCT 2006 (exact date is not needed but near) DCM: HCACAJAHB So anyone having a drive with these specs please respond. |
| Author: | rameez [ July 14th, 2008, 14:18 ] |
| Post subject: | Re: WD5000KS-00MNB0, DCM:HCACAJAHB needed |
Did u check the ROM contents ? How can u be so sure that the ROM is dead ? Is ur hdd spining or not ? |
| Author: | samppix [ July 14th, 2008, 15:19 ] |
I did send my drive to HDD recover specialist. They tried but were not able to get the drive to function properly. They have also tools for updating/reading ROM chips and my ROM chip was total dead, no data could be read from it... And they instructed me to find a compatible drive. As the only solution would be the ROM change (if a match is found). The drive would not even try to start on my motherboard internal SATA, so its very believable that ROM/Firmware is corrupted. With HighPoint SATA controller it tries to spin but stops after couple of silent clicks without mounting. |
| Author: | rameez [ July 17th, 2008, 15:22 ] |
I still dont think ROM is currupted where are u based ? |
| Author: | samppix [ July 19th, 2008, 15:23 ] |
Finland.. The recovery company has good reputation for ten years. What I discussed with them sounds very reasonable. Of course other opinions are welcome too. |
