 Post subject: WANTED: SEAGATE BARRACUDA 7200.8 300 GIG ST3300831A FIRMWAR
PostPosted: July 16th, 2008, 14:07
My drive spins up, but will not recognize in Bios. Need replacement controller.
300 Gbyte
ST3300831A
FIRMWAR E 3.01
No visible damage to board, but I'm desperate- worth the $$ to try.
 Post subject: Re: WANTED: SEAGATE BARRACUDA 7200.8 300 GIG ST3300831A FIRMWAR
PostPosted: July 17th, 2008, 15:17
Post a pic of the PCB .
PostPosted: July 18th, 2008, 2:52
PostPosted: July 18th, 2008, 3:00
Better do a proper diagnosis before buying a board.
Try to put the terminal-output of the board here. If you dont know how to do, look in other postings on hddguru. It's all explained there.
Best regards,
Dobre
Murphy was an optimist
PostPosted: July 18th, 2008, 3:26
Thanks for the advice. I'll read a bit more, then post the terminal output here.
PostPosted: July 18th, 2008, 9:16
Am I correct that to post the terminal output, I need to build this,
then connect it to the correct pins on the hdd,
and post the information as it appears in a HyperTerminal window?
Thanks!
PostPosted: July 18th, 2008, 9:36
That's pretty much it.
If you're alergic to soldering, you can get these premade on Ebay.
PostPosted: July 18th, 2008, 9:47
I'll throw it together this afternoon. If I wasn't so miserable about having lost my data, I'd say this is turning out to be alot of fun! Thanks for all the help.
PostPosted: July 18th, 2008, 10:20
It can be a lot of fun, if it's not your data :)
PostPosted: July 19th, 2008, 14:02
I have pcb for the drive u can PM for more info .
