| WANTED: SEAGATE BARRACUDA 7200.8 300 GIG ST3300831A FIRMWAR http://forum.hddguru.com/viewtopic.php?f=15&t=9419 |
Page 1 of 1 |
| Author: | aaustin [ July 16th, 2008, 14:07 ] |
| Post subject: | WANTED: SEAGATE BARRACUDA 7200.8 300 GIG ST3300831A FIRMWAR |
My drive spins up, but will not recognize in Bios. Need replacement controller. SEAGATE BARRACUDA 7200.8 300 Gbyte ST3300831A FIRMWAR E 3.01 No visible damage to board, but I'm desperate- worth the $$ to try. |
| Author: | rameez [ July 17th, 2008, 15:17 ] |
| Post subject: | Re: WANTED: SEAGATE BARRACUDA 7200.8 300 GIG ST3300831A FIRMWAR |
Post a pic of the PCB . |
| Author: | aaustin [ July 18th, 2008, 2:52 ] |
| Author: | dobrevjetser [ July 18th, 2008, 3:00 ] |
Hi, Better do a proper diagnosis before buying a board. Try to put the terminal-output of the board here. If you dont know how to do, look in other postings on hddguru. It's all explained there. Best regards, Dobre |
| Author: | aaustin [ July 18th, 2008, 3:26 ] |
Thanks for the advice. I'll read a bit more, then post the terminal output here. |
| Author: | aaustin [ July 18th, 2008, 9:16 ] |
Am I correct that to post the terminal output, I need to build this, Attachment: serial_max232.gif [ 9.61 KiB | Viewed 14960 times ] then connect it to the correct pins on the hdd, and post the information as it appears in a HyperTerminal window? Thanks! |
| Author: | rchadwick [ July 18th, 2008, 9:36 ] |
That's pretty much it. If you're alergic to soldering, you can get these premade on Ebay. |
| Author: | aaustin [ July 18th, 2008, 9:47 ] |
I'll throw it together this afternoon. If I wasn't so miserable about having lost my data, I'd say this is turning out to be alot of fun! Thanks for all the help. |
| Author: | rchadwick [ July 18th, 2008, 10:20 ] |
It can be a lot of fun, if it's not your data |
| Author: | rameez [ July 19th, 2008, 14:02 ] |
I have pcb for the drive u can PM for more info . |
