| WD1200VE-xxKWT0 required http://forum.hddguru.com/viewtopic.php?f=15&t=9562 |
Page 1 of 1 |
| Author: | pcimage [ August 5th, 2008, 10:05 ] |
| Post subject: | WD1200VE-xxKWT0 required |
With DCM to suit HOTJHBB. Thailand Cheers |
| Author: | Peterc [ August 5th, 2008, 10:39 ] |
| Post subject: | Re: WD1200VE-xxKWT0 required |
I have had trouble finding this drive. I have posted a question about the VE and whether it can be replaced with BEVS or other product designator. Any thoughts? I am currently seeking a PCB for mine. Good luck! Let me know where you find one. |
| Author: | pcimage [ August 5th, 2008, 10:59 ] |
BEVS is different, but UE would probably work. PCB I could possibly help you with. What the p/n of the PCB (2060 xxxx xxx)? Sean |
| Author: | Peterc [ August 5th, 2008, 13:54 ] |
I posted a 2061-701402-100 AB. You responded with 2060-701402-001 REV A. That wont work will it? Have you had any success with DR on the Scorpio? |
| Author: | thatdellguy [ January 22nd, 2009, 3:48 ] |
I'm seeing these WD1200VE-XXKWT0 all the time with detached heads. Its easy to find broken ones but almost impossible to find one that works. |
| Author: | pcimage [ January 22nd, 2009, 15:27 ] |
Yep, virtually every WD1200VE I've had in has had detached heads. Very little success in recovery, even with perfect donor. |
