HDD GURU FORUMS
http://forum.hddguru.com/
Wanted to Buy - Drive or PC Board for WD 160gb IDE
http://forum.hddguru.com/viewtopic.php?f=15&t=9586
Page 1 of 1
Author:  nanook [ August 7th, 2008, 17:43 ]
Post subject:  Wanted to Buy - Drive or PC Board for WD 160gb IDE
MDL: WD1600JB - 00FUA0
Date: 09 Jan 2004
DCM: HSBACVJAA
One down, one to go. Saved the data on my other HD that had the same fried component on the pc board - anything reasonabley close should do the trick.
Much appreciated!
Cordially
Glen
Author:  pcimage [ August 8th, 2008, 17:06 ]
Post subject:  Re: Wanted to Buy - Drive or PC Board for WD 160gb IDE
WD Marvel drive, you 99% surely will need the info off the ROM on the PCB, either read/write or physically xfer the ROM chip to the new PCB.
Author:  nanook [ August 8th, 2008, 18:24 ]
Thanks for your reply but I'm not sure I understand your directions. Can you explain or point me to a thread that can provide further details please?
The last WD drive (120gb) with the same burned out component, I just removed the old pcb and popped in the new one and it ran fine.
Author:  nanook [ August 8th, 2008, 21:48 ]
Here's a picture of the fried component on the pcb.
The pcb number is 2061-001179-000-DH
With the 120gb drive that had the same fried part (both taken out simultaneously by a failed psu) I just swapped in the new pcb and it fired right up (external drive).
Author:  rameez [ August 9th, 2008, 15:18 ]
I have this PCB in stock PM for details .
Author:  pcimage [ August 11th, 2008, 4:39 ]
oops. I was wrong, looking at the pic and having the PCB p/n helps. This isn't Marvel drive, I was thinking of GU family, not FU like this is.
PCB should work if ROM version is the same and the head map is the same.
http://www.phpbb.com/
