 Post subject: WTB: 2061-701450-Z00
PostPosted: August 11th, 2008, 10:25
WD1200BEVS-08RST2
Pretty commonly found in Lenovo 3000 and many others. Need PCB only. This unit has embedded flash. My drive does not power on at all. Motor tests good.
http://pcrecoveryllc.com
 Post subject: Re: WTB: 2061-701450-Z00
PostPosted: August 18th, 2008, 23:15
I've found two brand new donors, identical matches actually.
PostPosted: November 5th, 2008, 23:23
I'm looking for this same board (2061-701450-Z00) for a WD1600BEVS-00RST0. It looks like mine is electroplated (discolored on some of the contacts and no/really low voltage around the motor area), like something burned up in the circuit board. It makes a head moving sound 3 times, but the motor isn't going anywhere.
