 Post subject: wanted WD 2061-701477-800
PostPosted: August 17th, 2008, 21:24
I just need the board mine has a direct short on the input power line
 Post subject: Re: wanted WD 2061-701477-800
PostPosted: August 17th, 2008, 23:59
Have you tried to remove the TVS?
Dmitry
PostPosted: August 18th, 2008, 20:21
Sorry I ma Newbe at this but What is a TVS
PostPosted: August 18th, 2008, 21:47
If you do a search on here for TVS, you'll find all the details, ans it's been mentioned many times before. Basically, there is a single part, called a TVS, that protects the drive from power supply transients, and often fails by shorting. It's got to be the easiest fix in data recovery. No guarantees that's your ONLY problem tho..
Users browsing this forum: No registered users and 118 guests
