 Post subject: wanted WD 2061-701477-800
PostPosted: August 17th, 2008, 21:24
I just need the board mine has a direct short on the input power line
 Post subject: Re: wanted WD 2061-701477-800
PostPosted: August 17th, 2008, 23:59
Have you tried to remove the TVS?
Dmitry
PostPosted: August 18th, 2008, 20:21
Sorry I ma Newbe at this but What is a TVS
PostPosted: August 18th, 2008, 21:47
If you do a search on here for TVS, you'll find all the details, ans it's been mentioned many times before. Basically, there is a single part, called a TVS, that protects the drive from power supply transients, and often fails by shorting. It's got to be the easiest fix in data recovery. No guarantees that's your ONLY problem tho..
