Latest list of donor drives at 25 June 2009
http://forum.hddguru.com/viewtopic.php?f=18&t=12611
Author:  Odiferous [ June 26th, 2009, 8:59 ]
Post subject:  Latest list of donor drives at 25 June 2009
As header.
Please do not contact me via the forum - I don't visit it regularly. Best contact is via my website.
If you see a drive you need, please quote me the CODE - DAC xxxx so that it can be tested. Not all information relating to the drives is on the spreadsheet - only because some (original) columns contain private information.
I verify each drive before sending it (using MHDD scan) - please bear that in mind if you need a drive in a hurry.
Duncan
Donor drive stock 2009 06 25.xls [1.29 MiB]
Downloaded 2028 times
Author:  mob_dream [ June 28th, 2009, 8:56 ]
Post subject:  Re: Latest list of donor drives at 25 June 2009
Thank you Odiferous
