Discussions related to Atola Insight data recovery/Forensic suite, Atola Bandura standalone imager
Seagate Terminal LOG - error
February 6th, 2009, 7:15
Hi can Atola tell-me wich is this error?
Interface task reset
4096k x 16 buffer detected
MERCURY - 1_Disk    3.02  08-23-05 15:41
Buzz  - Head Mask FFFF - Switch to full int.
$Head Mask FFFF - Head Mask FFFF - Switch to full int.
ZeBong
Re: Seagate Terminal LOG - error
February 6th, 2009, 15:42
:lol: Good question to Atola gurus :lol: Any ideas? He-he :D
Actually, I suppose this terminal message from PC3K UDMA terminal appears when heads are dirty. Sometimes when you see many symbols $ in terminal it caused with lost servolabels. But in this case I suppose better to perform PCB swap and look again in terminal.
February 6th, 2009, 15:47
Hi that´s what i did it.
Afther change the PCB the error is different.
Buzz  - 23-05 15:41
              Spin Ready
3.02  08-23-05 15:45
(P)PATA Reset
$$$$$$$Head Mask FFFF - Head Mask FFFF -
But i think is easy for the tool to read the terminal and know what is it.
February 6th, 2009, 15:54
Now you can see that drive is spins, right?
Did you try to load from loader?
February 9th, 2009, 5:37
Come on....!!! If you don't know what this error means it is better to go and start baking cakes for your local cafe..... :O)
February 9th, 2009, 11:47
Did you perform any physical work on this HDD before this terminal output?
February 9th, 2009, 11:51
Yes, i haved change the heads and the PCB.
I Could make the disk :)
ZeBong
February 9th, 2009, 14:41
guru wrote:Come on....!!! If you don't know what this error means it is better to go and start baking cakes for your local cafe..... :O)
Ok, I will, but could guru say what is the problem exactly? 100%?
February 24th, 2009, 15:12
http://www.myharddrivedied.com/presenta ... paper.html
is says
13. Seagate Drives use a serial interface of which you can find online. It will show you stats on the drive. If you see FFFF mask FFFF mask it is a head error.
February 24th, 2009, 18:31
LiK wrote:http://www.myharddrivedied.com/presentations/presentations_whitepaper.html
is says
I suppose if scott moulton said it then it must be true..... :roll:
