| Seagate Terminal LOG - error http://forum.hddguru.com/viewtopic.php?f=19&t=11224 |
Page 1 of 1 |
| Author: | zebong [ February 6th, 2009, 7:15 ] |
| Post subject: | Seagate Terminal LOG - error |
Hi can Atola tell-me wich is this error? Code: Interface task reset 4096k x 16 buffer detected MERCURY - 1_Disk 3.02 08-23-05 15:41 Buzz - Head Mask FFFF - Switch to full int. $Head Mask FFFF - Head Mask FFFF - Switch to full int. $Head Mask FFFF - Head Mask FFFF - Switch to full int. $ Thanks ZeBong |
| Author: | Creator [ February 6th, 2009, 15:42 ] |
| Post subject: | Re: Seagate Terminal LOG - error |
Actually, I suppose this terminal message from PC3K UDMA terminal appears when heads are dirty. Sometimes when you see many symbols $ in terminal it caused with lost servolabels. But in this case I suppose better to perform PCB swap and look again in terminal. |
| Author: | zebong [ February 6th, 2009, 15:47 ] |
Hi that´s what i did it. Afther change the PCB the error is different. Code: Interface task reset 4096k x 16 buffer detected MERCURY - 1_Disk 3.02 08- Buzz - 23-05 15:41 Head Mask FFFF - Switch to full int. Spin Ready 3.02 08-23-05 15:45 (P)PATA Reset $$$$$$$Head Mask FFFF - Head Mask FFFF - But i think is easy for the tool to read the terminal and know what is it. |
| Author: | Creator [ February 6th, 2009, 15:54 ] |
Now you can see that drive is spins, right? Did you try to load from loader? |
| Author: | guru [ February 9th, 2009, 5:37 ] |
Come on....!!! If you don't know what this error means it is better to go and start baking cakes for your local cafe..... :O) |
| Author: | hddguy [ February 9th, 2009, 11:47 ] |
Did you perform any physical work on this HDD before this terminal output? |
| Author: | zebong [ February 9th, 2009, 11:51 ] |
Yes, i haved change the heads and the PCB. I Could make the disk Thanks ZeBong |
| Author: | Creator [ February 9th, 2009, 14:41 ] |
guru wrote: Come on....!!! If you don't know what this error means it is better to go and start baking cakes for your local cafe..... :O) Ok, I will, but could guru say what is the problem exactly? 100%? |
| Author: | LiK [ February 24th, 2009, 15:12 ] |
http://www.myharddrivedied.com/presenta ... paper.html is says Quote: 13. Seagate Drives use a serial interface of which you can find online. It will show you stats on the drive. If you see FFFF mask FFFF mask it is a head error.
| Author: | hddguy [ February 24th, 2009, 18:31 ] |
LiK wrote: http://www.myharddrivedied.com/presentations/presentations_whitepaper.html is says Quote: 13. Seagate Drives use a serial interface of which you can find online. It will show you stats on the drive. If you see FFFF mask FFFF mask it is a head error. I suppose if scott moulton said it then it must be true..... |
