Page 1 of 1
Failure during Automatic Check?
Posted: February 20th, 2009, 2:43
by falther
Starting with the version 1.2. of the software I have following problem, which
even remains with the current version 1.3.1:
Every time I start an automatic check of a hdd the first time, the programe
stops with an error - somewhere in / inbetween media test and smart test.
One can then choose to send the error report and then the programe terminates.
The second time I choose the same drive for the automatic test it works fine.
Anbody else faced with this problem?
My hardware: P4VN900 mainboard with Intel P4 CPU, 2.66GHz, 1GB Ram
320GB WD SATA HDD (in compatible mode) as system drive.
Re: Failure during Automatic Check?
Posted: February 25th, 2009, 21:42
by Dmitry Postrigan
Hello Walter,
Have you submitted the error report when Insight asked for permission?
Also, can you please send me a screenshot of the issue?
Posted: March 11th, 2009, 6:30
by falther
Happy to see that with the new version such errors disapeared.
All drives could be tested without interruption and the new
function to print reports is even better than suggested.
Imaging speed is amazing (unbelievable if one knows it is done with USB).
Walter
