| Firmware recovery http://forum.hddguru.com/viewtopic.php?f=19&t=12098 |
Page 1 of 1 |
| Author: | DriveDr [ April 28th, 2009, 16:19 ] |
| Post subject: | Firmware recovery |
Hi Maysoft, The supported drives list for Atola shows the statement below: " Seagate hard drives are not supported at the moment, but full support for these hard drives will be introduced in 2009" Do you know when we will be able to recover the firmware on Seagate drives through Atola? Is it close? Thank you! Dennis |
| Author: | Doomer [ April 28th, 2009, 22:25 ] |
| Post subject: | Re: Firmware recovery |
I see Atola supports all Toshibas (that probably means GSS and GSX too) I guess it beat PC3000 on this Also it beat PC3000 on Samsung Trinity and Nexus I guess And some Hitachies too |
| Author: | guru [ April 29th, 2009, 13:41 ] |
is this any good? I know the electronics will be good but not sure on SW side of things.. And whats the price? |
| Author: | DriveDr [ April 29th, 2009, 13:51 ] |
Hi Guru, The diagnostics are very good. When they add the firmware support for Seagate it will be much better. I'm having some issues with their serial port being able to unlock passwords but that should be taken care of tonight. We paid 7000.00 US for the Atola and we'll know soon enough if it is worth it. |
| Author: | guru [ April 29th, 2009, 14:09 ] |
WOW / KASHMAR thats a lot of money...... that really is lots of money.. I should sell all my things and buy a mansion in LA |
| Author: | Dmitry Postrigan [ April 29th, 2009, 19:49 ] |
DriveDr: At this time I cannot confirm the exact timeframe for adding full Seagate FW read/write support. However, there's a terminal available in Atola Insight. Although you won't be able to upload or download firmware modules, you still have access to all other commands. If you'd like to recover 7200.11 drives with Insight, then you can open the help pages (available from the menu) and then navigate to Seagate 7200.11 recovery instructions. |
| Author: | DMG [ June 8th, 2009, 18:21 ] |
I have several Hitachi Laptop Drives that I would like to be able to back up and restore firmware with the Atola. Model: HTS543216L9SA00 The model is not supported in the current version. Since I can't actually use Atola to back up the firmware will I be able to back it up in a different program and import it into the Atola Software or do I just need to wait until it is supported? |
| Author: | Dmitry Postrigan [ June 8th, 2009, 19:13 ] |
Atola Insight does not support L9SA hard drives at this time. If you use a different program and would like to convert into Atola Insight format, please drop us a line: http://atola.com/contact-email?type=1 (please just mention this topic to make sure I will receive your message) and I will let you know the details. Thanks! |
| Author: | DMG [ June 8th, 2009, 21:47 ] |
Thanks |
