Hard Drive Identification - Not Showing The Correct Info
http://forum.hddguru.com/viewtopic.php?f=19&t=12517
Author:  DMG [ June 16th, 2009, 1:33 ]
Post subject:  Hard Drive Identification - Not Showing The Correct Info
During the identification process I have had several drives report abnormal information.
On occasion it reports something different each time I try.
I have similar drives and identical drives that show correct information.
Is there a known bug or a way to fix this?
Author:  drc [ June 16th, 2009, 1:59 ]
Post subject:  Re: Hard Drive Identification - Not Showing The Correct Info
I see that sometimes, it's usually a bad IDE cable/connection.
Author:  Russwinters [ June 16th, 2009, 11:58 ]
Indeed, try a new cable. That is the only time I have seen that is when a cable went bad.
Author:  DMG [ June 17th, 2009, 0:05 ]
Yes it was the cable. Thanks for the suggestions.
Maybe the Atola can make that part of the program. BAD CABLE flashing across the screen when it doesn't recognize the drive correctly.
Author:  Dmitry Postrigan [ June 17th, 2009, 0:07 ]
DMG
Sometimes such identification can be a sign of a bad HDD PCB. This is why we haven't added something like that yet. I am not sure if there's easy way to deal with this...
Author:  guru [ November 26th, 2009, 6:48 ]
Myabe make a cappuchino while your doing your recovery?
