TOSHIBA MK6034GSX COD reported as bad PCB?
http://forum.hddguru.com/viewtopic.php?f=19&t=14057
Author:  mediaman [ November 24th, 2009, 23:48 ]
Post subject:  TOSHIBA MK6034GSX COD reported as bad PCB?
The disk has classic HSA symptoms but Atola 1.4 reports circuit board.
Any ideas?
Automatic Checkup Finished
Report date and time: 11/24/2009 at 7:30 PM
Device information:
TOSHIBA MK6034GSX
Serial number: X6F7T0AUT
Firmware revision: AH102E
Capacity: 117,210,240 sectors or 60,011,642,880 bytes
512 bytes per sector
Diagnostics results
According to the status register, circuit board is malfunctioning.
Full Diagnostic Log
Circuit Board (PCB)
Device is powered on. A power cycle is needed...
Applying power and watching spin-up currents...
Current oscillogram (12V):
Current oscillogram (5V):
Device is still not ready
Registers: 0101 0001 0001 0000 0000 0000 1010 Alt: 1010
Heads
Head stack cannot be diagnosed.
Author:  mediaman [ November 27th, 2009, 19:01 ]
Post subject:  Re: TOSHIBA MK6034GSX COD reported as bad PCB?
hellooooo (echoooo) is anybondy in heeeerrrrrrrreeeeeee (echoooooo) :?
Author:  Dmitry Postrigan [ November 30th, 2009, 19:19 ]
Hello Simon,
Sorry - I was traveling and unable to check the forum. If you need a fast reply, please use the Atola support forum (it is monitored by everyone at Atola Technology. You can access it by launching the Insight, and then navigating to Help->Support forum.
Now to your issue: can you please post the full log including the currents graph? You can export your log into .pdf or .rtf and then attach it here in the topic.
Author:  mediaman [ November 30th, 2009, 21:01 ]
Here you go! Thanks Dmitry!
TOSHIBA MK6034GSX.rtf [30.33 KiB]
Downloaded 1379 times
Author:  Dmitry Postrigan [ December 1st, 2009, 0:03 ]
Simon,
Thanks for the file!
It could be either heads or pcb. At this point I would swap the ROM onto a good pcb and then re-ran the diagnostics.
Author:  mediaman [ December 1st, 2009, 9:27 ]
(furiously looking for donor) thanks Dmitry, will try and feedback results. What does that register value mean?
Author:  Dmitry Postrigan [ December 3rd, 2009, 2:47 ]
Simon,
From the registers I can say there's potentially an issue with the interface part of the pcb. From the current graph I can say there's head damage. The only way to clarify is to rule out the pcb first. You will need a donor anyway, be it heads or pcb :)
Author:  mediaman [ December 17th, 2009, 10:29 ]
to follow up: it was heads in the end.
Author:  Russwinters [ December 17th, 2009, 20:20 ]
Good news! PCB with those Toshiba drives is not something to look forward working with...big headache unless you have a lot of $$ for the right equipment.
