 Post subject: Got today Atola Imager and have some problems + picture
PostPosted: August 24th, 2010, 6:37
Hi Everyone,
Today and finally I got Atola Imager :D
But when I try to connect it to the computer, I get this error messege
http://img685.imageshack.us/img685/6537/error2j.png
Maybe I connect the unite in a worng way? :?
I connect the unit to the computer with a network cable.
Before connecting the device I installed the software but after that I didn't do any settings in my IP adress, like default gateway or something.
I'm using windows 7.
I tried to shutdown the firewall but nothing.
What should I do?
Many Thanks!
 Post subject: Re: Got today Atola Imager and have some problems + picture
PostPosted: August 24th, 2010, 10:25
Try manually setting the IP address of your PC to something like 192.168.0.xxx (xxx can be any number from 1 to 253 except 177) and network mask 255.255.255.0. This should resolve your issue.
Dmitry
PostPosted: August 24th, 2010, 15:31
Thanks.
It is indeed solve my problem. :D
PostPosted: August 24th, 2010, 17:27
I had to reset the IP address on mine when it arrived. Perhaps you should remind dealers to reset the unit to default before it is shipped, or put a nice big sticker on the box saying the address may need to be reset, I had the find it in the manual, and I don't like manuals ;)
Data Recovery Ireland
PostPosted: August 24th, 2010, 21:34
That's a very nice idea! I will see if we can put a label somewhere. Maybe a removable label that sticks directly on the top lid?
Dmitry
PostPosted: August 25th, 2010, 6:39
yes, or perhaps a sticker over the ethernet port, which will be a nice reminder :)
PostPosted: August 25th, 2010, 6:52
I suggest to add it to the manual itself because in mine that line would have been very helpfull.
Don't like manual either :lol:
Thanks for the help!
PostPosted: September 2nd, 2010, 16:20
this is how you do it
print this out for future uses
1.
Open Network Connections
2.
Right-click the network connection you want to configure, and then click Properties.
3.
On the General tab (for a local area connection) or the Networking tab (all other connections), click the Internet Protocol (TCP/IP) component, and then click Properties.
4.
your see the following below input those numbers how you see it
Use the following IP address,
1) IP Address: 192.168.0.176
2) Subnet mask: 255.255.255.0
3) Default gateway: 192.168.0.177
done it will connect
but be warned if your using your windows updates
this can reset the ip adress to automatic
cron
