 Post subject: Atola Imager screws falling out
PostPosted: September 2nd, 2010, 16:29
ok not had much use but i heard something rattling inside my unit
out pops the following
2 washers
1 bolt
1 screw
the screw fell of the fan
lucky i did not plug the unit in or something bad might have happen.
i notice that the screws are not tight at all on the unit
you should check your screws around the fan.
and you want to check your fan screws
quality control needs to be worked on
as for putting these screws back in the unit
i have to open it up
but i dont want to as i still got a warranty left
 Post subject: Re: Atola Imager screws falling out
PostPosted: September 2nd, 2010, 23:15
2 washers
1 bolt
1 screw
Made in China? ;-)
