| Atola Imager screws falling out http://forum.hddguru.com/viewtopic.php?f=19&t=16898 |
Page 1 of 1 |
| Author: | craig6928 [ September 2nd, 2010, 16:29 ] |
| Post subject: | Atola Imager screws falling out |
ok not had much use but i heard something rattling inside my unit out pops the following 2 washers 1 bolt 1 screw the screw fell of the fan lucky i did not plug the unit in or something bad might have happen. i notice that the screws are not tight at all on the unit you should check your screws around the fan. and you want to check your fan screws quality control needs to be worked on as for putting these screws back in the unit i have to open it up but i dont want to as i still got a warranty left |
| Author: | fzabkar [ September 2nd, 2010, 23:15 ] |
| Post subject: | Re: Atola Imager screws falling out |
craig6928 wrote: ok not had much use but i heard something rattling inside my unit out pops the following 2 washers 1 bolt 1 screw the screw fell of the fan Made in China? ;-) |
