 Post subject: Atola - PCB Hot Swap
PostPosted: May 26th, 2011, 22:41
I want to do a PCB Hot Swap using an Atola Insight but I'm not sure it supports it. The unit has a device->spindown option that when applied appears to stop the motor while retaining power. I assume this function exists to perform a PCB hot swap but I can't find it documented anywhere and I don't want to mess up the unit.
Has anyone used the Atola for a PCM hot swap?
Regards,
Dave
 Post subject: Re: Atola - PCB Hot Swap
PostPosted: May 28th, 2011, 12:45
Hello Dave,
Device->Spindown is exactly what you need. Do not worry, the hardware unit has all kinds of power protection (including persistent shorts/over-current).
Dmitry
Users browsing this forum: No registered users and 70 guests
