 Post subject: USB Media Blaster
PostPosted: January 18th, 2011, 22:29
Hi Everyone,
Is this product enable me to perform images from external drives with USB only to sata drives?
http://www.hdd.ji2.com/products/brochur ... laster.pdf
Sometimes I get bad external drives with degraded heads. I want to perform images from those bad drives to good drive. The problem is that those drives come with USB only.
I cann't plug those drives to Atola Imager and perform the imaging at all.
Is this product enable me to perform the imaging and also image by heads for drives with USB only to sata drives?
Best Regards,
 Post subject: Re: USB Media Blaster
PostPosted: January 19th, 2011, 12:44
Unfortunately going through USB directly to the HDD comes at a price; speed is certainly one of these, but also you lose the ability to issue certain commands that you would be able to issue through SATA.
So unfortunately this product will not allow you to perform selective head imaging, etc.
Regards,
PostPosted: January 19th, 2011, 19:25
Regards,
Hi Russel, Thank you very much for the informative answer :)
What imaging ability this prodcut gives me (if at all)?
Regards,
PostPosted: January 20th, 2011, 14:05
This product was designed for duplicating *good* USB HDD; such as the ones that are factory sealed so that you cannot open without voiding warranty.
Regards,
PostPosted: February 2nd, 2012, 6:36
Hi Guys
I was wondering if anyone else has any more comments about the USB Media Blaster for use with the Atola Insight?
1. Should this work fine for imaging an external USB drive that only has a few bad sectors?
2. Should it work for imaging Western Digital USB drives that have the Initio (AES versions) chip, where a password has not been set?
Alternatively, has anyone used or recommend these products:
CPR Tools: IDE to USB Adapter
SalvationData: SD Dedicated USB-IDE Adapter
Thanks in advance.
Cris
PostPosted: February 2nd, 2012, 13:02
The only REAL solution for USB drives with hardware issues is to convert to SATA :-(
Easy enough if you know how! :-)
PostPosted: February 18th, 2012, 15:59
I think the best solution for USB drives is to remove the hard drive from the case.
This way you are dealing with a regular SATA or older IDE drive and you don't need to deal with the limitations of USB. If this is a data recovery job with bad sectors etc., saving the data is usually worth more than worring about the warrantee or the cost of the drive. Just my opinion.
PostPosted: February 18th, 2012, 18:03
See http://www.datarecoverytools.co.uk/2010 ... tor-suite/
